Technical T/A Trekking Alternator?
Liteboy
Cambridgeshire
Yesterday on the way to work my wife had a few odd things on the dash, the gear change up/down indicator seemed to throw a wobbler at one point telling her to change up when she was in top gear and the external temp sensor suddenly dropped to - 2 plus the car is running a bit rough.
When she got home I put a meter on the battery it was 12.7v with or without the engine running which seems low to me.
I put it on my ctek charger overnight and the battery went up to 13.9v and once off charge stabilised at 13.31v.
I reconnected everything and the battery stayed around 13.31v, started the car and it didn't rise or drop even with a load on from the lights, heater and heated window.
All the earth's look OK and the battery is a Yuasa 7000 series battery I put on in 2021.
I also connected up the laptop with multiecuscan to see if there were any errors logged but only had two errors from a while ago, one was the knock sensor and one was a DRL failure I hadn't cleared nothing else.
I am thinking alternator hoping it isn't as it looks a right pain in the.... to get to.
Can you measure voltage via accessory socket headlights on vent fan on whilst driving going down a hill with accelerator not pressed at all?
If you have a smart alternator those are the conditions which should cause alternator to operate
Note that Pandas with Stop/start have ‘intelligent alternators’, which means that at some times they offer very little charge but at other times (low engine load such as going downhill) they briefly charge the battery (which relies on a reverse current across the plates) at as much as 16 volts. A modern stop/start battery should read 12.8 volts a few hours after last being driven. If it down to 12.5 it’s 50% depleted and if below 12.2 lots it’s had it.
I picked up one of those voltage display gadgets for the cigarette lighter socket yesterday. Initially when plugged in it read 12.5, on my wife's journey to work this morning it read 13.3 most of the time but went up to 14.8 under braking down hill from 50mph. When she got to work it showed 13.1 without the engine running, she is going to check it on her lunch break to see how much it has dropped. So I am now suspecting the battery is on its way out. 👍
12.1v after sitting for about 4 hours and 12.2 this morning before going to work. Have ordered a new battery.
New Bosch battery fitted, car seems to be running fine except for the exterior temperature sensor which is on the replacement list now.
Another one added to the list: ‘odd behaviour, warning lights and/or error codes cured by battery replacement’. With more modern batteries and charging systems, this really should be the first thing tried before changing anything else, unless the battery is less than a year or two old 🙂
My recently purchased Alfa Twinair, warns "alarm unavailable"
It only does this on ColdStarts..
as if the 18 month old battery struggles to keep a decent float charge..
But it will run S/S reliably, so presumably "ok"
I suspect a warranty exchange may be on the cards
