Technical Fiat 500x interior door trim right side
Bporsch
West Lafayette, IN
Hello,
I'm not sure if I've posted this in the right place. I noticed 2 parts of the interior door trim on my fiat 500x are loose. It is on the right side, and I will attach some pictures. There is one portion in the corner that has a blue piece that doesn't attach anywhere.
There is also the midsection that lacks connection points. It looks like maybe they have broken off. Does anyone know the name of what the replacement parts would be called? Is there a way to reattach without having to replace the whole pieces of trim?
Thank you in advance, any help is appreciated!
The Blue item on the lower wheel arch trim is a push button clip.
See: https://vehicleclips.co.uk/products/exterior-body-moulding-trim-clips-fiat-735537083
Looks like it has popped out of the hole in the wing.
The yellow item is similar but in this case the slot/channel on the back of the side trim has broken away leaving part of it still attached to the groove in the yellow trim clip head.
NOTE! US part numbers are completely different to EU/UK.
