TheGreenMachine
- Joined
- Sep 7, 2020
- Messages
- 9
- Points
- 31
Well the time had come where I thought it was time to clean up and repaint the rear axle/beam on my Panda 100hp. I was fairly sure that apart from being a bit scabby that the axle was fairly solid. The spring pans are pretty solid. I used wire cup brush on a grinder, which works exceptionally well, maybe a bit too well. The welds on the bottom of the V -shaped centre section where they join the outer radius arm sections vanished in an instant and on the passenger side a crack appeared all the way around and over the top of the outer arm
If you are checking your rear axle for rust I would suggest not to just look at the spring pan area but every weld, and check them with a good couple of whacks with a hammer!
Luckily I have managed to source a complete replacement rear axle from Spain which looks in absolutely fantastic condition.
