Here will be all the common problems with ICE such as headunits and their associated car model. Please check here before created a new thread If there are any other known common problems, PM me the problem and solution and i'll add them here
SONY HEADUNITS IN STILO:
The problem is that the Stilo has no switched live feed due to the on/off functions of the original factory head unit being controlled by the CAN system.
In their infinite wisdom FIAT have decided to put the live feed on the ISO block in a position which works with most aftermarket head units once you swap the inline bullets on the red and yellow wires round - I say most as this isn't the case with the Sony looms.
Having fitted a CDX-CA900 head unit in my Stilo (now in my Mondeo) I quickly found that no combination of the bullet connectors powered the unit up and resorted to swapping the position of the red and yellow wires in the ISO end of the Sony loom and then connecting both the male bullets to the double female. Also did this on Bo~Select@'s Stilo a couple of weeks back when he swapped to a Sony MP3 unit.
It's an easy job to do - just poke something long and thin (I used a 12v test probe) up the side of the two blades you want to swap (this releases the retaining tabs) and then remove them from the ISO block. Before pushing the blades into their new locations you will need to gently bend the retaining tabs back out so they do their job. Once the blades are swapped, connect the ISO bloks and you have a working Sony head unit.
The other option is to obtain an ISO extension (i.e. a straight through cable), cut the red and yellow cables and crimp Male/Female bullets inline to avoid altering the Sony loom - this way you can cross the cables if needed depending on the requirements of the head unit.
Thanks PurpleMonday for providing a solution
