jimmy jimmy
hello i have a fiat punto mk2b sporting 1.4 2003.
Here in greece last summer when the car was parked in the sun for 8 hour ( while i was at work) then it could not be started. The starter motor is new. The car was trying to start but not cranking. After 2 or 3 starting tries car starts ( sometimes i press a liitle the gas pedal and starts running with a little rough idle and after some seconds it is smooth) . When the car has started then it runs smooth and if i turn it over and try to start it , it starts ok( and when it warms up).
All the winter season it had no problem, now that days around 30c outside and the car was parked under shadow , it had again this problem. I turn the key, the starter motor turns and the engine turns but i noticed that the rev counter was trying to get up but it was playing arround the zero 0 . No errors comes up.
I tried one more time and then it started ok.(rouhg idle some seconds and pressed a little the gas pedal and was smooth after)
i have suspicious that it might be the crank sensor fault in hot weather.
the car is in excellent condition mechanically with its all services etc.
