Technical Random cutoffs, or engine not starting
Hungary
Hi
I have a 2000 Fiat Seicento 1.1 Sporting. The problem started 2 days ago. So the car started to do this thing: at small throttle - 0.5 second stall - then it goes again, but when i shut it off and try to start again it doesnt want to start unless i try to start in a gear and make a normal start. Then the problem solves for a few minutes of drive. This also happens when i want to take off in 1st gear and it chokes itself or i dont know. The problem doesnt come up unless the engine is warmed up. OBD showed a P0335 CKP sensor problem, but it randomly disappears and shows up on every 3rd or 4th startup. I've recently bought 4 NGK spark plugs and a new fuel filter but havent changed them yet. Any suggestions? Last time it stalled in 3rd gear and coasted to a parking lot :D
Thank you for your help!
Gabor
