Technical Punto shuts down randomly when driving
Janttila
Hi
I have Punto 2004 which shuts down when driving. It doesn't start immediately but when disconnecting battery minus for a while it starts normally. This is very harmful fault. I have done temporary fix by adding relay to the plus wire which goes from battery to fuse box ( in motor compartment). When car switch down I just push button inside and relay switches electricity off for a while and the car is again running normally.
What could cause this kind of problem?
Br. Jari
Hi
Br. Jari
Hi again
I have made some more experimental with this problem. I changed the ecu, immobilizer box and ignition switch. It seems that the problem still exist. It doesn't give any error codes so its very difficult to proceed.
br. Jari
It's really difficult to give any good advice. If it was me, when it cuts out & won't start, I'd see what's missing (fuel or spark) & work back from there.
Hi again
br. Jari
I am guessing a bit here as to what is causing the problem and what might fix it.
Which ECU do you have? One possibility is one of the 12V wires to the ECU has an intermittant connection which then needs you to reboot the ECU. Normally the ECU is always running so it will not reboot until the power is disconnected. These cars are getting quite old so you might need to unplug all the fusebox plugs check them for corrosion and reinsert them to get rid of the corrosion.
Hi
The problem is that this shut down occurs randomly and usually when I'm driving in traffic and there isn't time to search the issue. Just push the button for reboot and go on.
Jari
Hi
I'm not sure which is the version of ECU. I changed the ECU to another one together with new key and immobilizer box and the problems seems to continue. So the ECU electricity could be the reason. I have to check the fuse box for corroded joints. I suppose it's the fuse box in the motor compartment because I changed the inner fuse box together with immobilizer box. Thanks for suggestion.
Br Jari
@Janttila Have you fixed your problem and cant be bothered to update people of are you still driving around in a random stop/start car?????
Its always polite to update people who try to help you and anyone else has the problem in the future!!!!!!!!!!!!!
After I cleaned the motor compartment fuse box connectors the failure haven't appeared. I have made around ten drives without shut down.
Br. Jari
If the problem reapers, first thing ckeck and replace the crankshaft sensor. Also, check the main earthing cable that goes from battery (-) to the body and forward to the gearbox.
