Service Items:
Not sure what gearbox and/or differential oil to use? Here is all you need to know!
Electrical:
Lights, Gauges, and other electronics not doing what they should? this should help you out!
Fiat Panda Classic Light bulb list
"Help! my Light switch has stopped working... why??" here is why. <<please read my reply post in that thread here
Brakes:
Brake line Flare type, Size, and Union type
Engine:
Things to check over on the engine if running rough
903cc OHV (push rod) Engine Cylinder head torque and bolt tightening / undoing pattern
FIRE engine Timing Marks
Gearbox & Drivetrain:
Gearbox and Differential oil seal sizes - All you need to know
Torque setting for the front axle nut
Suspension:
High Tensile Bolt specs for the panda 4x4 (mk2)
Track Control Rod / Tie Rod bush size
Alternative front coil springs for panda 4x4
General:
Websites with Mk1 AND Mk2 Panda Specifications and Performance Ratings
Modifications:
How to fit a 16v engine into a classic Panda
Punto engine going into a panda? need help with the wiring? click here!
This is currently in development.
please stand by...
If you feel that you have made a thread that would help someone out in the future and contribute to the Panda Facts thread, please do comment it below and i will add it to this list. after its been added to this list in this post, the post below will be removed to keep this thread clean.
Electrical:
Brakes:
Engine:
Suspension:
General:
Modifications:
please stand by...
