Wiltshire Chris
Accidental Barchetta owner
I thought it was time to address the two minor leaks that my B has. They're both near the front passenger side wheel and mean I have a plastic tray permanently on the garage floor to catch the drips. There is definitely oil and coolant in the tray and I think I've identified the leaks correctly as:
- A small coolant leak from the pipe that comes forward from the header tank and then bends back. I suspect this is just getting a bit old and perishing. I'll drain the coolant down a little and take a look at the pipe.
- The other one that concerns me is, I suspect, a small oil leak form the front right corner of the rocker cover. I can order a new gasket from shop4parts and the manual covers the process of changing it in decent detail. The thing I'm not sure of is whether I should also use some gasket sealant as well. I've seen views that say you shouldn't need to but others that say to do so (including Paul in ). I'd rather not do the job twice so I thought I'd solicit opinion here as well as ask for sealant recommendations, I've heard Hylomar Blue mentioned and someone recommended ELRING Dirko Ht in the comments to Paul's video but I don't have any real basis to make a decision so any thoughts are welcome.
