croma4ever
- Joined
- Feb 15, 2021
- Messages
- 16
- Points
- 52
Hi all,
We have a Fiat Croma 2.0 ie which was bought from new. Is there any chance that you have any Wiring Diagrams (namely, Engine, Ignition, ECU, etc.) for it?
Here are the details:
1987 Fiat Croma 2.0 ie (super version) Ignition and Fuel Injection Weber
(It must be the Weber system, as opposed to the more popular BOSCH)
Problem - The cold start is terrible and when it does eventually start, the throttle needs to be feathered for a few minutes until the engine warms up, otherwise it will stall……. Then, it will maintain tick-over. When driving, the engine just lacks power and if you try to accelerate more the engine just ‘chocks-up’ and the speed drops. Easing off the accelerator allows for the car to pick up but the acceleration is just so slow…… Once, I hit a slight bump in the road and the engine went dead…. Fortunately, the motion of starting the engine allowed for a reconnection and the engine started. Therefore, there seems to be a connection problem somewhere down the line.
(I have visited your Forum and found an owner posting a message with EXACTLY the same issue! The response was that it could be a loose connector or broken wire. The problem for our mechanic is that without a wiring diagram it is near impossible to solve. If he has a plan, then he will know what wire goes where and can pass an electrical current through it in order to test it. The ‘Earth’ is good, by the way)
New parts – ECU, Distributor, Temperature Sensor, Connection Block for Coil.
Result – No resolve but the car is far more efficient in terms of fuel…..
Any help much appreciated!
