Immobiliser help!
Immobiliser help!
Midlands
Hello everyone. I have a 2011 Qubo 1.3mj.
Immobiliser light comes on with ignition and no start on key turn. Changed key battery with no luck, I don't have a 2nd key .
Any advice or tricks to try? Would rather not have to get a new key made and coded.
I read somewhere some Fiats have issue with grounding cable or something?
Thanks for any help guys :)
I take it this is a remote key, open the key look at the narrow end of the printed circuit board,
if there's a oblong black component have a close look at the connections for cracks in the solder,
try gently pushing the connections towards the component see if it works, if so it needs re-soldering
a job best left to someone that is good with a iron.
