H Howiedean New member Joined Nov 24, 2005 Messages 21 Points 8 Mar 4, 2021 #1 Hi, I've had an intermittent fault code P0130 popping up which throws up the engine light. Has anyone experienced this on the 1.6 Diesel Multijet? Any ideas, is this normally a sensor or the wiring? Regards, Howie
AndyRKett Distinguished member Parked in the garage Joined May 23, 2011 Messages 14,432 Points 3,413 Location Norfolk UK Mar 6, 2021 #2 Howiedean said: Hi, I've had an intermittent fault code P0130 popping up which throws up the engine light. Has anyone experienced this on the 1.6 Diesel Multijet? Any ideas, is this normally a sensor or the wiring? Regards, Howie Click to expand... It’s a generic oxygen sensor code that applies to any car. Basically means the oxygen sensor is not getting a consistent reading which is either the oxygen sensor or exhaust leak.
