W Willow esta New member Joined Mar 16, 2024 Messages 1 Points 1 Location Bedford Mar 16, 2024 #1 Hi I have a fiat 500 66 plate and the clutch pedal feels loose we have added fluid as there wasn't anything in there I can put it into gear when the engine isn't on but when I start the car I won't go into gear and it jumps
rmjbn1 hello Parked in the garage Written 5 reviews Joined Oct 25, 2018 Messages 1,035 Points 408 Location West Clare Mar 16, 2024 #2 Hi and welcome Have you bled the clutch slave cylinder to get rid of any air in the system? You also need to find where the leak is and fix it. You should be able to see if it's wet with fluid around the leak. Slave cylinder most likely, but could be master or quick connector in left front wheel arch. Last edited: Mar 16, 2024
