Technical Dualogic problem new clutch
Scotchgitt
Scotland
Not had a fiat since the late 80’s with my 127sport
I bought a cheap 2009 qubo 1.3 multijet with dualogic that needed a clutch
Dropped the gearbox and clutch plate was completely worn
Fitted new clutch and rebuilt the car
System primes when i open the drivers door
When i move over to manual everything is ok
But when i select + i get a few nooses and clunks from gearbox side then check transmission error
Any advice?
Fluid level ok and clutch fluid ok too
got my elm327 and multiecuscan license
got connected to the car car immediatly
downloaded all errors, havent deleted any yet until i do a bit of digging about calibrating the clutch
not sure how old some of these are
3 in engine
P0683-13 - Preheating glow plugs signal - Open circuit
U0422-82 - Inertia function (FIS) - Alive/sequence counter incorrect/not updated
U0001-88 - CAN line error - Bus OFF
4 in gearbox
Errors found:
P2912-98 - Clutch sub-system - Component or system over temperature
P2913-62 - Gearbox sub-system - Signal compare failure
P0561-1C - Battery voltage - Voltage out of range
P2915-72 - Gearbox sub-system - Actuator stuck open
7 in body
B1053-86 - Inertia (FIS) switch command Engine Control Node - Signal/message invalid
B10AA-4A - PROXI configuration control - Incorrect component installed
U1703-87 - Instrument Panel node - Missing message
U1724-87 - Parking Sensor Node (NSP) - Missing message
U1706-87 - Brake system (NFR) - Missing message
B1009-16 - Battery voltage - Voltage too low
U1733-87 - Convergence Telematic Node (L1 and L2) - Missing message
0 in abs woohoo
I plan charging battery then resetting all of these and then rescan
Well that was easy, reset all codes
Ran a bleed twice
Ran a self calibration
Ran final calibrated
Went for a drive
