Technical 1998 100 16V air con pipes leaking. Need replacement
UzY3L
Hello,
The air con pipes on my car are leaking. They've been welded before but the weld didn't last and pressure testing revealed a leak exactly where they have been welded.
I've looked around the net and on this forum but I didn't find anything related to the pipes themselves, most people have compressor, gasket or refrigerant issues.
Found a set of pipes online but they told me they aren't compatible with my model, only with the facelift. Thought they were the same?
Mine are supposed to be:
46527795
46525773
which match numbers 5 and 9 from the picture which I got from https://fiat.7zap.com/en/mul/1f/18621000-022/501/1+50101s02+2-0/
However, the shop I found the pipes at told me they only have:
51745115
46804650
I have little experience with these schematics but from what I've read in the above link, all part numbers are for the same part so they should apply to both pre and post facelift models but wanted to confirm.
Could someone please help me out with this?
Hi, varesecrazy,
Thank you for pointing me toward ePER. Unfortunately, I get an Error 500 when I try to use it. Tried it with three browsers, including IE but I get the same. Is there anyone I can contact about this? I'll try again tomorrow.
