Many people think, that a weak turning signal lever is caused by hard rubber boot over the lever. It may be true to some degree, but main issue is worn tip inside the lever mechanism.
On the right is 18 years old tip from a turn signal lever and on the left is new looking tip from a wipers lever.
These tips slide inside grooves, but when the tip is dull, it will not hold inside a groove and fall out easily.
