Tools required.
Clutch centering tool
36mm socket
Multiecuscan software and ODB2 cable
Be very diligent about labelling all cables and hoses before they are removed so you have no doubt where they go back. Most of the electric plugs are obvious but the hydraulic hoses need to be marked clearly to go back in the same place they came from (there aren't that many)
Ball-joint popper.
Bottle of selespeed oil
2 litres gearbox oil for the gearbox itself
Antifreeze.
Clutch kit and release bearing recommended.
Flywheel optional. (I did mine)
![DSC00979.JPG DSC00979.JPG](https://cdn.fiatforum.com/data/attachments/140/140954-0be52738232094e079a88f28e768650a.jpg)
36mm socket
Ball-joint popper.
Antifreeze.
