Tonycott
Hi has anyone got knowledge of a 1970 Fiat 850 special good or bad
Good, I’d have one, just look out for the tin worm and keep the radiator clear, blow out the fins with air, not waterHi has anyone got knowledge of a 1970 Fiat 850 special good or bad
Can I ask why you wouldn't use water? Not full on jet wash but just a garden hose is what I use once every two years. I take the rad out, flush it and then from the opposite side to the fan I back flush.Good, I’d have one, just look out for the tin worm and keep the radiator clear, blow out the fins with air, not water
The 850 has a multitude of water traps, better to blow out with airCan I ask why you wouldn't use water? Not full on jet wash but just a garden hose is what I use once every two years. I take the rad out, flush it and then from the opposite side to the fan I back flush.
Curious
Oh ok, normally I take the rad out, take off the shroud and then with a standard hose nozzle and some foam cleaner rinse through the fins. Will reassess this the next time!The 850 has a multitude of water traps, better to blow out with air
I guess, if you’re stripping it all down, water won’t collect in any of the panels, rails etcOh ok, normally I take the rad out, take off the shroud and then with a standard hose nozzle and some foam cleaner rinse through the fins. Will reassess this the next time!
