General Body roll
General Body roll
Ive had the tank punps connected wrong way around.
Is the front wiper wiping..but the water going to rear..??
The front wiper works while pulling back on the stalk but the washers spray the rear whilst doing so when I push the stalk towards the dash it sprays the front but I have to put the wipers on to clear the screen
that sounds like the pump wiring..
the stalk operation sounds relatively normal for a FIAT.. cannot remember what the Idea switches functions were like.
I currently drive 5 x FIAT cars.. they are ALL DIFFERENT...
where abouts do you live..?? Carmarthenshire..?
charlie - Oxford
Pushing my stalk away operates the REAR washer jet and pulling it towards me operates the FRONT washers jets and wipers.
So his is wrong somewhere.
I THINK you are BOTH saying that ( counter-intuitively..) ;
you push the stalk towards the FRONT for rear wiper/wash,
and towards REAR for front wiper/wash
that's the general feeling of "normal" I have in a FIAT..:rolleyes:
the time I had it , it was a PIA..as the TIPO TD had mechanical headlamp wipers/washers..and they worked with the REAR stalk operation:spin:
swapping the pump motor cables fixed it..(y)
charlie - Oxford
I live in Pembrokeshire not far away from Carmarthenshire
I was just wondering if it would be an MOT fail
I'll remove the black trim under the bonnet and see what's what maybe they've put the connector upside down or something into the pump motor
Any ideas about the steering to the left slightly now I've changed the n/s/f shock
Need alignment ?
I spent a fair amount of time in Llandovery area:)
MOT fail..
technically. as long as you have a switch that RELABLY puts water on the screen ( on demand) then it'll pass,
:idea: remove the rear wiper - then it's not being classed as serving the REAR
though I'd spend 1/2 hour swapping the plugs on the tank motor 1st
see my basics guide:https://www.fiatforum.com/miscellan...-clogged-screenwash-pump-tank-focus-tdci.html
Need alignment ?
Normal recommendation when changing shocks is to do them in pairs, as now you have one new shock and one old one both operating slightly differently due to age/wear. Hence why it's probably pulling to the left slightly (which I assume is the side you've changed).
Normally recommendation when changing shocks is to do them in pairs, as now you have one new shock and one old one both operating slightly differently due to age/wear. Hence why it's probably pulling to the left slightly (which I assume is the side you've changed).
Now you've said it like that it's got to be that cheers will either get another shock or align the beast next up for mine is window tinting and silver grill ha recently had cambelt waterpump full service and brakes done on 83k currently
Last cars fiat panda4x4 oldshool one fiat Uno mk2 punto, Grande punto ,fiat 500 and now this little beauty
Big up the Italian massssiiiive
