Anyone out there know how to configure MultiECUscan for my ’53 plate Stilo 1.6?
I’ve just bought myself an ELM 327 interface V1.4, the associated cables and I am using the free MultiECUscan software (I will buy the full version once I know I can connect). My intention is to reset the service warnings on my Stilo and my wife’s 500 (I have done the oil & filter changes).
Starting with the Stilo (as my wife has the 500 for work) I’ve connected the ELM 327 device using the yellow cable (which I believe is correct?) but I can’t get connectivity. I have set the latency of the PC via Device Manager to ‘1’ as per instructions, and I’ve set the MultiECUscan software to port 14 to match the PC (USB Serial Port).
After several attempts and trying different settings I am getting the following message when scanning for interfaces (copied word for word) –
VagCom/KKL interface found at port COM3
ELM 327 1.3+ interface found at port COM14 speed 38400bps
This interface is compatible with ELM 327 1.4! Should connect properly with all CAN modules.
Latency too high!!
COMPLETED
Also, if I run a test using the MultiECUscan software I can several sucessfully completed tests until it reaches –
COMMAND: ATBI
RESPONSE: CAN ERROR>
Warning: This interface is not compatible with ELM 327 1.3!
Will not connect to any CAN module.
Am I being a numpty and doing something stupid?
Latency too high!!
COMPLETED
COMMAND: ATBI
